H DISTRIBUTOR WORN ???
Bob R
09-06-2000 08:52:52
The distributor on my H has a lot of play at the breaker cam shaft . What is the recommeded play for this ? This thing really is loose .
The houseing is nice and tight .
I was going to try and run it and see if the timeing is stable with a timeing light .
any ideas ?
Thanks everyone
Bob R
09-06-2000 09:21:49
 Re: H DISTRIBUTOR WORN ??? in reply to Bob R, 09-06-2000 08:52:52
The play is directly between the post and breaker cam assembly for the timeing advance . looks like a bushing can be replaced in the hole for the breaker cam part . the caseing accually is perfect , no play at all .
I might not of been to clear on my previous note
The Red
09-06-2000 09:28:58
 Re: Re: H DISTRIBUTOR WORN ??? in reply to Bob R, 09-06-2000 09:21:49
I don't know if there is a bushing in there that can be replaced or not. The parts manual doesn't show one.
Bob R
09-06-2000 09:40:13
 Re: Re: Re: H DISTRIBUTOR WORN ??? in reply to The Red, 09-06-2000 09:28:58
Thank you very much for looking that up for me Red
I think I will run it , like you said there are tracors with worn distributors out there doing fine .
Thanks again
T_Bone
09-06-2000 11:35:54
 Re: Re: Re: Re: H DISTRIBUTOR WORN ??? in reply to Bob R, 09-06-2000 09:40:13
Hi Bob, There's nothing that says you can't have a bushing made for it if it don't have one or make one yourself. Depends on whats cheaper. Rebuilt or the bushing.
T_Bone
The Red
09-06-2000 09:03:35
Bob the distributor housing is worn. There should be no lateral play. Set the points around .017 to ensure they will close. My neighbor's M distributor has been worn like that for years and it runs fine. Eventually the distributor housing will need to be replaced.
