Farmall Super C Tractor
Bob Almstrom
01-08-1999 15:06:19
Hi:
I am having trouble with hyd. oil getting by the seal and going down into my oil pan. I pulled the hyd. oil pump, and noticed lots of wear on the lead and involute of the pump gear. If there is a strain on the gear won't there be a strain on the shaft and seal? then allowing the hyd. oil to go on by? Any help will be appreciated, thank you.
Bob
C. Amick
01-12-1999 09:29:01
 Re: Farmall Super C Tractor in reply to Bob Almstrom, 01-08-1999 15:06:19
Usually if the shaft moves around, it will wear the seal. If you have the number off the seal you can likely find a replacement at industrial bearing and seal suppliers. They may have one that will fit the shaft a little tighter. I buy all my seals and bearings from a company that supplies the mining industry. Hope this helps a little.
