Trying to start my F12
Brian
09-11-2000 16:28:04
Ok, It's time... I've been trying to start my F12 with no success. The mag has been rebuilt, and I finally got the timing correct. I also have been adjusting the main fuel needle screw in accordance with the operators manual(2 1/2- 3 1/2 turns out). But all I have been able to get is a pop here and there, and my arm is getting TIRED!!
Any ideas or suggestions? Thanks, Brian
RB
09-11-2000 16:39:39
 Re: Trying to start my F12 in reply to Brian, 09-11-2000 16:28:04
#1.....Get a buddy to pull it off!
#2.....Dont choke it.I pulled my hand crank for hours to no avail.Let it sit for about an hour,no choke,she started right up.That was my only problem.Others may can help more.
Doug
09-11-2000 17:12:18
 Re: Re: Trying to start my F12 in reply to RB, 09-11-2000 16:39:39
Carl
09-11-2000 20:10:33
 Re: Re: Re: Trying to start my F12 in reply to Doug, 09-11-2000 17:12:18
i just went through the same thing a month ago, after we got the tractor completely back together, i pulled and pulled on the crank. finally got tired and pulled it out side and put her in gear and eased off the clutch. within 10 yards she popped and came to life. you should have seen the carbon and crude that came out of the manifold. After that the tractor starts real easy if, you only choke it for one crank. hope this helps.
