Order Farmall Cub Parts Online
CUB CARBURETOR PROBLEM
BUZZ BRUCE
09-15-2000 05:07:37
I JUST REBUILT MY CUB IHC CARB. WHEN I REINSTALLED THE FLOAT AND CHECKED THE FLOAT LEVEL IT WAS 3/16" MORE THAN SPEC! SET TO SPEC & REINSTALLED. TRACTOR RAN FINE. BUT AFTER SHUT OFF A WHILE GAS STARTED TO DRIP OUT OF FUEL BOWL DRAIN. TOOK APART AND SET FLOAT LEVEL 1/16" BEYOND SPEC. SAME PROBLEM- BOUGHT A NEW FLOAT/ SAME PROBLEM-CAN SOMEONE PLEASE HELP ME! THIS IS DRIVING ME CRAZY! THIS PROBLEM DID NOT EXIST PRIOR TO OVERHALL. THANKS BUZZ
C.Fitz
09-16-2000 16:47:52
 Re: CUB CARBURETOR PROBLEM in reply to BUZZ BRUCE, 09-15-2000 05:07:37
Had the same problem with my Cub; and all I did was remove it and sat it on the work bench to paint the tractor. Put it back on the tractor and it would not stop leaking. Re-built it , re-did everything and would not stop leaking after shut=down. Ended up buying a new one . Problem solved. I bet yours is a Zenith? Good luck.
BUZZ
09-17-2000 06:37:58
 Re: Re: CUB CARBURETOR PROBLEM in reply to C.Fitz, 09-16-2000 16:47:52
THANKS FOR THE GOOD NEWS! MY CARBURETOR IS NOT A ZENITH BUT AN IH. I THOUGHT I HAD MY PROBLEM CORRECTED, BUT AFTER 4 OR 5 HOURS IT STARTS TO DRIP. I'M CONVINCED THE PROBLEM IS THE NEEDLE VALVE AND SEAT! DOES ANYONE OUT THERE KNOW WHERE I CAN BUY A QUALITY NEEDLE VALVE AND SEAT??
THANKS BUZZ
Phil Auten (TX)
09-15-2000 10:25:20
If you replaced the needle/seat when you rebuilt the carb, the needle isn't "matched" perfectly to the seat. Take the carb apart and with the needle installed against the seat, give it a couple of light taps with a brass or plastic mallet. This will match the two parts together so they seal properly. Note: this only applies to the all brass needle. If your needle has the black tip, do NOT use this procedure.
Phil
BUZZ BRUCE
09-15-2000 14:46:26
 Re: Re: CUB CARBURETOR PROBLEM in reply to Phil Auten (TX), 09-15-2000 10:25:20
THANKS PHIL I FOLLOWED YOUR PROCEDURE AND NOW IT WORKS JUST GREAT. I HAD INSTALLED A NEW VALVE AND SEAT. YOU HAVE BEEN MOST HELPFUL!
BUZZ
T_Bone
09-15-2000 05:50:57
Hello Buzz, The needle and seat is probablly bad. The needle should have a grove around the tapered tip if bad. They should be replaced by pairs as both needle and seat.
T_Bone
BUZZ
09-15-2000 14:56:25
 Re: Re: CUB CARBURETOR PROBLEM in reply to T_Bone, 09-15-2000 05:50:57
HI T BONE THANKS FOR YOUR HELP VERY MUCH APPRECIATED.
BUZZ
