PTO hp on different models,
bronco
09-18-2000 20:41:08
What is the pto hp for the following; 1958 Cub, a Cub Low Boy same year, a Yellow Cub (int)1960's and a Farmall 130 ???
Joe Evans
09-21-2000 20:21:41
 Re: PTO hp on different models, in reply to bronco, 09-18-2000 20:41:08
Phil, Cubs and Cub Low Boys of the 1958 model year likely are rated at 10.39 max belt horsepower as recorded at Nebraska. The latest test of a Cub by Nebraska was done in 1956. The 60's vintage machine likely is the same rating. Nebraska did not run PTO tests until 1959 as belt ratings fell out of favor because of the declining use of belt powered equipment. PTO ratings are slightly less than what would be recorded at the belt pulley. The 130 was tested at Nebraska in 1957 and yielded 21.38 max belt HP. My dad has a sharp looking 130 with a 60" Woods belly mower. This machine is a mowin' fool! Joe
Phil Auten (TX)
09-19-2000 04:14:11
Bronco,
All Cubs including the Lo-Boys run between 8.9 and 10.5 HP, depending on wether you use the Nebraska tests or IH's published HP figures.
Phil
