Loose steering A
B--MACK
09-22-2000 21:20:22
THE STEERING IS LOOSE ON THE A ALSO HOW CAN i TIGHTEN IT?
redhead
09-24-2000 07:15:08
 Re: Loose steering A in reply to B--MACK, 09-22-2000 21:20:22
All the loose play may not be in the steering box. Check the tie rod ends and the set bolts on the upper spindle assemblies. Wheel bearing could be loose or worn too. Good luck.
Vern
09-22-2000 22:08:55
Check the arm where it bolts around the shaft beneath the steering box.
Ridge Runner
09-23-2000 19:09:25
 Re: Re: Loose steering A in reply to Vern, 09-22-2000 22:08:55
A few years a old Dad and I were going to fix the front end of his A. We went to the IHC dealer to buy parts. the parts man brought out a sealed bag for $20. I suggested to my Dad we check what was in the bag. Only a thick washer, a castel nut and cottter key. We did not buy the bag, instead we went to the hardware store and spent Less than $1. Placement of the washer will depend on the location of the play.
