Could this be my valves
Bish.
09-26-2000 07:50:27
Now I know I need a clutch.But today I got her(Farmall A)good and warm and she started smoking at idle(oil smoke)and with no load,but when I got on the hill of my driveway and it loaded a little it stopped smoking about 95%
Is it time for a valve job or overhaul?
I changed the oil the other day and used 30wt.
If I do need a valve job or overhaul how much will it cost.Oh yeh my oil pressure is good and high.
Farmall Gray
09-26-2000 14:15:04
 Re: Could this be my valves in reply to Bish., 09-26-2000 07:50:27
I have the same problem with my BN. When you have the valve job done I recomend you put umbrella type valve guide seals in it. This will help keep oil out. They are available from NAPA. I work at a NAPA store and I got a set for mine but haven't had a chance to put them in yet.
The Red
09-26-2000 07:56:41
Bish oil is getting down your valve stems. The guides usually wear before the rings wear out. I wouldn't consider that bad enough that it needs to be done immediately. That would be a good winter project though.
Bish.
09-26-2000 09:22:45
 Re: Re: Could this be my valves in reply to The Red, 09-26-2000 07:56:41
Does that mean machine shop or anybody with mechanical know how?
The Red
09-26-2000 09:34:51
 Re: Re: Re: Could this be my valves in reply to Bish., 09-26-2000 09:22:45
NAPA charged me about $125 in labor for a Farmall H head last year and did the following.
Boiled. Magnifluxed.
Shaved.
Installed new exhaust seats. Ground intake seats. Replaced valve stem guides. Replaced manifold studs. Installed new valves and springs.
The one thing I forgot to have them do was seat the valves with compound. So I had quite a bit of valve clearance adjustments over the first 10 hours of running. I had TISCO valves seating into grouind IH and new NAPA valve seats.
Glenn: Question
09-27-2000 07:55:11
 Re: Re: Re: Re: Could this be my valves in reply to The Red, 09-26-2000 09:34:51
Red, what was the total price they charged you? So far, that $125 sounds pretty reasonable.
The Red
09-27-2000 10:10:24
 Re: Re: Re: Re: Re: Could this be my valves in reply to Glenn: Question, 09-27-2000 07:55:11
Parts and labor ran me around $275 total for the head if I recall correctly.
Bish.
09-26-2000 10:59:54
Thanks for your time and advice.
