More F-20 ? from a 17 yr. old
Adam
09-26-2000 19:50:53
here are some more questions about my F-20.
1. The head, after hot tanking shows cracks. One is from the spark plug hole out onto the compression dome and then stops. The other is on the top where the rocker arms mount. How should this be fixed because I would like to keep this tractor number matching for shows.
2. Does anyone know if NAPA or anyone else carries the timing cover gaskets? How about the gaskets that go between the parts of the manifold?
3. If you've got a good picture of a 39 farmall.... POST IT! I have decided to use this as the focal point of my lifes collection. Thanks Guys
Al P.
09-27-2000 15:58:29
 Re: More F-20 ? from a 17 yr. old in reply to Adam, 09-26-2000 19:50:53
Adam;
I am currently restoring 1938 F-20. I have got the front end pretty much done and will take apart rear end next year. Rice Equipment (814) 226-9200 is your best Source for Parts as they specialize in farmall F series. you may need a big bank account though. your head cracks may be fatal but I am not an expert. I only had cracks between two water legs on my head.
Al P.
Haas
09-27-2000 06:57:02
If you happen to need a cast iron steering wheel for you F-20, I have one. Look in the classified ads here at YT.
Oldtractor
09-27-2000 06:54:55
third party image
Here you go Adam 1939 eletric start, hysler roar gear and fends, a option you don`t see often.
Adam
09-27-2000 20:00:51
 Re: Re: More F-20 ? from a 17 yr. old in reply to Oldtractor, 09-27-2000 06:54:55
You tractor looks great!!! I now have a picture of it on my wall for motivation. Thanks for the other pictures and replies. keep em comin!
jiM
09-27-2000 03:35:40
Adam, look under the community heading and go down to your stories and check the story named "coming home" there is a '39 there for you to see.
