Order Farmall Cub Parts Online
Cub Hydraulic problem
Bob D.
09-30-2000 19:11:41
Just purchased a 1950 Cub and have a problem raising & lowering the front mounted snow plow.Whereas the action should be smooth & controllable, mine has a very jerky & intermittant movement.I've cleaned/greased everything externally & there is no binding in any of the linkages. Does the hydraulic unit & lines need to be bled?If so, whats the best procedure? Also, what kind of oil is best for the hydraulic unit? I've been told 30 wt engine oil,ATF,hyd jack oil,etc.Any advise/comments will be appreciated.
Bill {Antique Acres}
09-30-2000 20:19:32
 Re: Cub Hydraulic problem in reply to Bob D., 09-30-2000 19:11:41
You can use ATF oil in it. It will not hurt anything. There are others that can be used as well, as long as they are non-foaming. Bill {Antique Acres}
gene b
09-30-2000 19:43:30
hy systems use hy oil sounds like air is in the system also if this is not the case could be head gasket in the rockshaft assy
