F20 head gasket
Bruce
10-02-2000 19:48:33
Anyone know where i can get a Felpro head gasket
for F20? Just had the head redone and the head
gasket won't seal. I know that felpro gaskets
are reliable, but can't find any in my area.
Any help would be appreciated. Need the head gasket and part no. and also the manifold and
water jacket gasket.
gene b
10-03-2000 02:37:12
 Re: F20 head gasket in reply to Bruce, 10-02-2000 19:48:33
try high temp aluminum paint several coats
Daniel M.
10-02-2000 20:28:00
Bruce,NAPA has a head set that is still available,part #HS 454,it has a head,manifold,water jacket and various other gaskets.before you install the head gasket be sure to put some copper coat on both sides,also at available at NAPA,and you shouldent have any problems as long as the block and head are clean and not warped.good luck Daniel M.
