F-20 skips a beat
Al P.
10-05-2000 13:33:01
I am trying to debug a problem with my f-20. while it is running it seams not to fire on one cylinder every other revolution. its like seven beats and #8 misses. any ideas?
Al P.
ltf in nc
10-05-2000 13:41:58
 Re: f-20 skips a beat in reply to Al P., 10-05-2000 13:33:01
Check for burr or point setting too close. Check around carb for air seeping in around gaskets, manifold or worn shaft bushings. Check the compression on all cylinders and compare for uniformity
Andy Martin
10-05-2000 18:45:28
 Re: Re: f-20 skips a beat in reply to ltf in nc, 10-05-2000 13:41:58
And if those ideas don't help, try running a little Marvel Mystery Oil in the gas. You may have a valve just beginning to stick and MMO would lubricate it.
