C distributer drive
Andy
10-11-2000 06:34:10
Hi! I need some help. I am looking at a locked '50 farmall c. I think it is locked in the cylinders, the guy still has the trailer he backed in hooked to it and there is gas in the fuel bowl. Anyway, the guy told me I can buy it if I can get the gear that drives the distrubiter and hydraulic pump on his super C he wants to keep. ( he wants to keep the 2-pt.) know what gear i'm talking about ? know where to get one ? how much would it cost ? I looked at the walt's link in one of the other questions and they listed a dist. drive shaft. does it come with the gear I need? the guy told me the gear went bad beacause the bearing went bad and fell into the gear and broke it. Is this a common problem with farmall C's and super C's ? thanks for the help !
Andy
10-15-2000 09:25:19
 Re: C distributer drive in reply to Andy, 10-11-2000 06:34:10
I talked to the guy about the tractor, he don't think it is locked. Maybe it isn't. the only way i've tried to turn it over is with the battery charger on the battery. He says the starter could be jammed, And i've heard of this happening. thanks !
gene b
10-11-2000 19:25:33
are you talkin about the govener gear with the wts the timing marks are on the front better take the housing off so you can get it in proper registration the dist drives with a little piece with splines going into the dist the other end has like a t handle this enguages into the backside of the govener
Andy
10-11-2000 13:27:49
Looked at the tractor even closer this afternoon. I found a long rod connecting the throttle to an arm in front of where the gear would be. on the other side is another arm with a rod connecting to the throttle. I assume these two arms are connected by a rod in front of the engine. Hey experts Is the gear I'm looking for a governer gear? sure looks like it to me. By the way, I'm Andy Mills, not the guy with 806 troubles. Thanks for the help in advance.
