Water Pump on 806
Andy
10-11-2000 10:05:31
I have an 806 diesel and noticed the other day with the tractor idling, the fan blades and belt had some side to side motion. It appears that the bearings that hold the water pump shaft that the fan blades bolt to are going out. I have no water leaks. It appears to me that the water pump is in 2 pieces, an internal cartridge that contains the volute and shaft, etc and the pump housing that bolts to the front of the block. I am looking for anyone's input whose has had experience replacing these water pumps. Case IH dealer quoted me 185 for complete rebuild of pump instead of replaceing bearings in cartridge unit. Any suggestions would be appreciated.
Norm
10-11-2000 18:22:55
 Re: Water Pump on 806 in reply to Andy, 10-11-2000 10:05:31
Put one in my 806D last summer about a $100 from worthington ag parts for a rebuilt pump. My hoses were shot so it was several more dollars.
WJP
10-11-2000 17:38:19
try calling shoup in Kankakee,IL they usually have good prices and anything over $100. is shipped free.also have them send you a catalog the phone number is 1-800-627-6137
ltf in nc
10-11-2000 20:01:16
 Re: Re: Water Pump on 806 in reply to WJP, 10-11-2000 17:38:19
Shoup does not have this particular water pump. You now have to buy $150 to get them to pay the shipping. Found this out on my last order. I do like doing business with them.
T_Bone Pump Parts List!
10-11-2000 11:50:14
Hello Andy, Here's the part numbers for the water pump. Can you get them cheaper than what ltf quoted for a rebuilt pump? And I have not rebuilt a water pump on a tractor but have on my pressure pump for the house and even with a SS pump shaft it was eat-up pretty bad.
326721R1 SPACER, wa 1 TC100 D-16
333794R91 SEAL, wate 1 TC100 D-16
ST715 BEARING, w 1 TC100 D-16
ST441 BEARING, w 1 TC100 D-16
610051C91 SEAL, pump 1 TC100 D-16
603722C91 SEAL, wate 1 TC100 D-16
265164C91 SEAT, wate 1 TC100 D-16
Here's the guy I buy my parts from, very reasonable and very good service!!
Link
ltf in nc
10-11-2000 10:45:12
My catalogs indicate that a reman pump is available for approx. $98. The rebuild kit is the same price. Since I am cheap and lazy, I would order the reman and a gasket an save the difference.
Les Repair
10-11-2000 17:20:42
 Re: Re: Water Pump on 806 in reply to ltf in nc, 10-11-2000 10:45:12
If you can get a rebuilt pump for #98.00 it's a bargain. Make sure it's for a diesel with a 361 engine. My book has one for $140.00 shipped to you.
Jim
10-11-2000 10:42:12
To take the waterpump off of an 806 you will need to take the radaitor out of the tractor. There isn't enough room to take the water pump out.
Andy
10-12-2000 06:24:55
 Re: Re: Water Pump on 806 in reply to Jim, 10-11-2000 10:42:12
Not sure of your tractor configuration but I got my water pump out without removing the radiator. Question is are you referring to the internal cartridge that has the shaft and volute or the entire housing? I removed the entire housing by unbolting and coming out sideways.
Jim
10-12-2000 10:39:49
 Re: Re: Re: Water Pump on 806 in reply to Andy, 10-12-2000 06:24:55
You took it of the had way.
