Farmall H Belly Pump Oil
Bob R
10-14-2000 16:09:35
I was curious about the oil to use in the Belly pump . I have a Saginaw three point hitch adapter .
And am concerned this might damage the seals .
Should I put engine oil in like the book says ?
Thanks people
Bob R Yes I do Operators Manual McCORMICK
10-15-2000 06:09:14
 Re: Farmall H Belly Pump Oil in reply to Bob R, 10-14-2000 16:09:35
The paragraph reads: Fill the lift-all to the full mark on the bayonet gauge with a clean , good quality engine oil of the same viscosity as used in the engine of your tractor . It should be filled when the implements are in the down position .
This is directly from the Farmall H Operator's Manual . Thats why I was wondering , with new equipment , like the three point hitch , That damage may occur to the seals . I had a bucket on this tractor with hydualic cylinders and I am sure motor oil was in the system .
Anyone been through this ?
Andy Martin
10-15-2000 12:44:17
 Re: Re: Farmall H Belly Pump Oil in reply to Bob R Yes I do Operators Manual McCORMICK, 10-15-2000 06:09:14
Thanks. I don't have an Operator's Manual, guess I should get one!
I use hydraulic fluid so I can't help as to whether motor oil would indeed damage cylinder seals, but I expect that it would.
Andy Martin
10-14-2000 20:01:13
You have a book that says to use engine oil in the belly pump?
BTD
10-15-2000 15:58:12
 Re: Re: Farmall H Belly Pump Oil in reply to Andy Martin, 10-14-2000 20:01:13
I have a reprint of the original manual for my M. It says use the same oil as in the engine. It goes as far as to add the however that one should not used drained engine oil.
BTD
Norm
10-14-2000 16:40:44
Use Hy Tran.
