Update on oil to use for Belly pump
Bob R
10-15-2000 07:43:04
I called Saginaw tractor today , and the owner said to use 30 weight motor oil . They did not have hydraulic oil back then . They built the three point hitch .
Just wanted to follow up on this . It was interesting to know what to do .
Thanks for your replys
Bob R hi tran it is + another question
10-15-2000 14:36:47
 Re: Update on oil to use for Belly pump in reply to Bob R, 10-15-2000 07:43:04
I am going to put the hy tran in . Sounds like the best bet . I drained the old oil out ,
Should I flush it out as well , and if so with hy tran too ??? Not sure of a good flush for this ...
Thanks a bunch for the feed back everyone
The Red
10-15-2000 15:08:57
 Re: Re: Update on oil to use for Belly pump in reply to Bob R hi tran it is + another question, 10-15-2000 14:36:47
Bob I wouldn't worry about flushing it.
T_Bone
10-16-2000 02:39:22
 Re: Re: Re: Update on oil to use for Belly pump in reply to The Red, 10-15-2000 15:08:57
Hi Bob, One thought. Your pump was designed for 30w oil and hy-tran is very thin oil of 10w. Will the pump pressure up being designed for a heavier weight oil? And the pump has seen some orperating time since new so is worn a bit.
My son says they been using 10w/30 motor oil on new hydraulic equipment for several years without any problems here in Arizona where summer temps demand a heavy weight oil. When I talked with our local IH dealer he stated the HY-tran worked just great during the summer heat. Sons says BS! Colder climates it might not make any difference.
I just changed my oil in my 340U with a Pippin loader/hoe and used 10w/30 motor oil. It looked like it had watered hy-tran in it before I changed it, about 1gal of pure water drained. Pretty sad shape as the oil looked carmel colored. Were at 55 at nite and 80 degrees during the daytime and before the change the hydraulic system was poor at best. After the change it was like I put in a new hydraulic pump. More work needs to be done on the seals but the seals do leak less using the 10w/30. I'm putting in new seals this winter so I'll be the test for all ya'll on whether motor oil damages seals or not. :)
T_Bone
kev@IA
10-15-2000 14:23:18
Something to considder, if you are gonna hook up that tractor to implements that more modern tractors use as well change over to HY Tran so the oils don't get mixed, don't know that it's a proablem but generaly not a good idea.
my 2 cents
kev
The Red
10-15-2000 08:30:52
Non-detergent SAE 30 is fine. You can also use JD Hy-gard or Case Hy-tran for modern day hydraulic oils.
