Super M cam gear successfully replaced
Bob M
10-16-2000 08:53:59
Followup to my post a couple weeks ago - this tractor had the nut unscrew off off the camshaft, letting the cam gear gradually flop itself to death inside the timing gearcase...
Got the new cam gear installed this weekend. My idea to secure the key in the damaged keyway with JB Weld did not work (just like T_Bone predicted...) - the key popped out 1st time I tried to fit the gear into place. However I found by using a new Woodruff key, the new gear has a nice force fit on the camshaft - it drives the camshaft solidly even before installing the cam nut. Put on a new nut keeper, treated the threads with blue Loctite, then torqued the cam nut to 150 ft-lb. When I got all done the camshaft had 0.010 endplay - exactly per spec - and the cam gear ran true when cranked.
Put the gear cover back on, then test ran the engine. It started right up, ran nice and that annoying knock is GONE!. Found also the low idle speed has increased by 100+ RPM - probably due to the valve timing now being back where it should be. Only let it run a minute (no radiator or coolant yet) but am satisfied with the repair.
Next up is to reinstall the front end and radiator assembly - this weekend weather permitting.
Thanks to all who offered advice and support!
Bob M
Farmer Bob
10-16-2000 21:08:14
 Re: Super M cam gear successfully replaced in reply to Bob M, 10-16-2000 08:53:59
Bob M, Glad to hear it worked out fine. I'll let all know how the H I'm working on comes out. This gem had the idler gear between the distributor gear and the cam gear 180 out plus two teeth. Still busy removing broken off bolts in the front bolster and motor mounts. Too many tasks - not enough time!//FB
The Red
10-17-2000 09:42:46
 Re: Re: Super M cam gear successfully replaced in reply to Farmer Bob, 10-16-2000 21:08:14
Was that the H that the Pratt's previously owned?
Farmer Bob
10-17-2000 20:46:20
 Re: Re: Re: Super M cam gear successfully replaced in reply to The Red, 10-17-2000 09:42:46
yes
Bob M
10-17-2000 09:05:09
FB - Guess I got lucky with mine. Someone greased the bolster and motor mount bolt threads before putting 'em in - every one of them came out nice and easy.
Bob M
The Red
10-16-2000 09:01:37
Congratulations Bob and thanks for posting the happy ending!
