Bigger MD problem
Bill M.
10-22-2000 12:51:33
My MD was surging on the diesel side as previously described in "MD problem". Took it on a 15 mile drive to try to clean it out (and gave it a bath) and when I got back I noticed it was leaking oil on the gas side. Pulled the dipstick to see if the oil was down and instead found that it had mysteriously made oil instead. The oil appeared to have leaked out from the valve cover gasket. I assume that the apparent problem with the injector pump may be causing it to dump fuel into the oil? Any suggestions as to the likelihood of this? My local IH dealer gets a blank look on when asked questions about MDs and is no help. Any help appreciated.
Bill M.
10-22-2000 17:06:54
 Re: Bigger MD problem in reply to Bill M., 10-22-2000 12:51:33
From previous advice about the surging on the diesel side I had checked the pump oil and found it full of what appeared to be mostly old diesel. I replaced it with fresh 30wt before driving it to the car wash. I drained it again today and tho it was somewhat dirty looking it didn't seem to have lots of diesel in it.
Andy Martin
10-22-2000 13:01:47
Likely the front seal on the injector pump, coupled with diesel leaking into the pump. What is the oil level in the pump, and does it appear to be diesel?
