1951 M Farmall Engine Block Problems
Brent R
10-22-2000 13:51:33
I'm rebuilding engine - water is getting into oil. Looking up from bottom, with oil pan removed, I can see drops of antifreeze towards front of engine. Local machine shop says they can "magna-flux" to find possible crack in block. Am I wasting my time and money? If they do find crack how will they repair and will it hold? How much does a used block typically costs? THANKS!!!
Jim
10-23-2000 08:04:39
 Re: 1951 M Farmall Engine Block Problems in reply to Brent R, 10-22-2000 13:51:33
Is the coolent at the bottom of one of the liners or is coming down from the front of the block?
Some blocks have a frost plug in behind the front cover.
jakee
10-22-2000 17:19:31
most M blocks crack behind the dry sleeves. you can then bore out the bolck and set a new wall then fit the dry sleeve,if you find another block make sure ti has the right main cap,s on it.or you will have to line bore it.
