M Farmall
Timing Marks on CAM and Crank Gears
Brent
10-23-2000 20:31:13
I'm rebuilding M Farmall engine. Noticed who ever worked on engine last did not line up single punch mark on camshaft gear with single punch mark on crankshaft gear - it's one tooth off. Is there a reason they did this or did they just not take the time to line up properly? When I assemble again should I line it up properly or leave as is? THANKS!!!
Pam Hall
05-29-2003 18:54:18
 Re: M Farmall - Timing Marks on CAM and Crank Gear in reply to Brent, 10-23-2000 20:31:13
I need to know what the settings are on a 88 isuzu?
Dale13
10-24-2000 01:55:00
 Re: M Farmall - Timing Marks on CAM and Crank Gears in reply to Brent, 10-23-2000 20:31:13
The timing was advanced one tooth which equals about 7 degrees.Thiss was done to further boost the low end power.It works. If it ran well before like this I would put it back in the same way. I just finished my Super M a month ago and I did the same thing.
Farmer Bob
10-23-2000 21:32:00
Brent, Do yourself a favor and line it up properly like the manual says. If you ever sell it and someone else has to work on it we will probably see another post just like yours. The marks are there for a reason like the manual says. Good luck with the M.//FB
