SUPER A CRANKSHAFT UPDATE
BRAD
10-28-2000 12:42:58
A FEW WEEKS AGO I POSTED A MESSAGE TO TRY TO HELP ME LOOSEN A STUCK CRANKSHAFT. IN THIS TIME PERIOD I HAVE PUT PENTRATING OIL IN THE SPARK PLUG HOLES AND LET THEM SIT FOR ALMOST 8 DAYS. DIDN'T BUDGE. ALSO I TOOK THE HEAD OFF AND SPRAYED PB BLASTER DIRECTLY AROUND THE PISTONS AND LET IT SIT FOR 3 DAYS. STILL NOTHING. AM I TO THE POINT WHERE I HAVE TO REMOVE THE BLOCK FROM THE TRACTOR AND GET DIRECTLY TO THE CRANKSHAFT OR ARE THERE ANY OPTIONS THAT I CAN PURSUE?
Bob R
10-28-2000 14:21:55
 Re: SUPER A CRANKSHAFT UPDATE in reply to BRAD, 10-28-2000 12:42:58
You could drop the oil pan . Take the main and rod caps off, that you can get to . most likely a piston is stuck . You might be able get at the piston if you can turn the crank away .
You could also hit the piston useing a block of wood . Maby shock the piston loose . Be carefull and take your time .
Anyone else help ?
Andy Martin
10-28-2000 19:52:48
 Re: Re: SUPER A CRANKSHAFT UPDATE in reply to Bob R , 10-28-2000 14:21:55
I've had good luck driving pistons out using a sledge hammer on a piece of wood, from below. Expect the sleeve to come up with it.
Do all pistons seem to be stuck, or can you tell which one? Usually one or two show corrosion when you get the head off a stuck tractor. If they don't look stuck, pull a rod cap and try removing one.
