Farmall H Head gasket + timeing cover leak
Bob R
10-29-2000 06:02:34
Hello ,
Was not sure about when to retorque the head gasket . I ran it an hour so it got to operating temperature . Should I retorque hot ?
I really have to get the book on this some day .
I have a new gasket and used RTV Blue sealer on the timing cover . The top middle bolt has a few drops a minute leak . Is there supposed to be a copper washer here ? Thanks
The Red
10-29-2000 06:32:05
 Re: Farmall H Head gasket + timeing cover leak in reply to Bob R, 10-29-2000 06:02:34
Bob you could stick a copper washer on there but no it did not come with one.
I would run a couple of hours on the engine and then retorque. I also retorqued around 29 hours but only the two middle bolts were slightly out of torque.
Bob R
10-29-2000 06:34:56
 Re: Re: Farmall H Head gasket + timeing cover leak in reply to The Red, 10-29-2000 06:32:05
Thanks
I'll get out there and do this .
Red Raider
10-29-2000 17:25:01
 Re: Re: Re: Farmall H Head gasket + timeing cover leak in reply to Bob R, 10-29-2000 06:34:56
When you re-torque, be sure it's a cool engine. A warm or hot engine will cause the torque values to change.
