Tach for 300
Bill M
10-29-2000 08:20:34
I have a 300 row-crop with a non-working tach. Would like to have a working one. Anyone know where such may be found?
Thor
10-30-2000 13:52:02
 Re: Tach for 300 in reply to Bill M, 10-29-2000 08:20:34
Bill,
Are you sure that your tach is the problem? Just went through the same experience with my 300 row crop. It turns out that through the years the inside of the tach cable conduit got filled with crud and the tach cable eventually bound up. This in turn made the plastic tachometer drive gear go "sneakers up". I took my cable apart, cleaned everything really well, and now the cable turns nicely in the conduit. I'm going to paint my cable conduit and then lube it with a synthetic oil and put the tach cable back in it. I checked and you can still get the tachometer drive gear from your local CaseIH dealer. The part number is 369 695 R91 and it costs 35 to 40 dollars.
Hope this helps,
Thor
dick
10-30-2000 07:07:58
I believe that Bates is now in the tach business
Link
You might also try this contact which was suggested to me as a source for a used tach
Mike Franzen at 319-673-6631
I have no experience with either, and would appreciate it if you would post yours. One of these days I'll get around to getting my tach replaced/overhauled, and it would be nice to have info from someone who's already done it.
