6vto12v.
Ben
10-29-2000 08:35:28
I had heard somewhere that it is possible to convert a 6volt generator to a 12 volt generator. Is this possible?
Vernon Wagner
10-29-2000 08:55:34
 Re: 6vto12v. in reply to Ben, 10-29-2000 08:35:28
Absolutely! I just went thru a nightmare concerning that. I've a 51 International I-6 with a 6 volt pos ground. The previous owner tried to switch over to 12 volt neg ground and did everything wrong. So in my adventure I took both the generator and the starter down to have them rebuilt.( because they were fried) The fun began when I learned (after 250.00)that no one was sure if both were rebuilt as 6 volt or 12 so after alot of trouble I was able to speak to the fellow who actually did it and confirmed that they were rebuilt as 6 volts. Thank God! My only delema now is this:Now that ALL electrical components have been replaced with original parts for 6 volt pos ground system including ALL wires and connectors The engine turns over nice and strong but I am not getting spark so of course it won't fire.TOTALLY STUMPED!!!
The Red
10-29-2000 09:03:01
 Re: Re: 6vto12v. in reply to Vernon Wagner, 10-29-2000 08:55:34
Vernon for a quick trouble shoot, hotwire the coil switch and see if you get spark.
VW
10-29-2000 09:12:47
 Re: Re: Re: 6vto12v. in reply to The Red, 10-29-2000 09:03:01
Yes, Thank you.I did pull the plug from the dist.and hold it to clean metal as my wife pressed the starter button. NO SPARK. Is that what you were referring too?
The Red
10-29-2000 09:15:14
 Re: Re: Re: Re: 6vto12v. in reply to VW, 10-29-2000 09:12:47
No. Does your tractor have a coil switch like on the H?
The Red
10-29-2000 08:40:55
You sure can Ben. I have had 3 or 4 H generators converted to 12 volt over the past 10 years.
Ben
10-29-2000 12:25:28
 Re: Re: 6vto12v. in reply to The Red, 10-29-2000 08:40:55
O.k. two more question I thought of, Do i have to have the starter converted over also? and Do I have to go with heavier wire,cables,connects? I upgraded more of wires to a 12 or 14 gauge and battery cables are new. Thanks for your help!!
The Red
10-29-2000 15:04:39
 Re: Re: Re: 6vto12v. in reply to Ben, 10-29-2000 12:25:28
No the starter will be fine as a 6 volt. It just spins faster. Cable wise, the 6 volt cables are more than adequate for a 12 volt system. You can actually get by with thinner cables on a 12.
