Farmall 560 specs, NH 518 too!
Brent
10-31-2000 13:30:56
I am purchasing a Farmall 560 (with loader) and a New Holland 518 spreader from my uncle in Minnesota. I was wondering if anyone new the length and or weight of these two items. I would like to haul them both on the same trailer as it is a 350 mile trip back home and I don't want to make two trips. I would probably get the spreader on the gooseneck first and then drive the tractor on with the loader resting in the spreader. Any info would be appreciated.
sammy the RED
10-31-2000 17:19:38
 Re: Farmall 560 specs, NH 518 too! in reply to Brent, 10-31-2000 13:30:56
NH 518 is 2240 lbs.
560 gas w/narrow front is 5898 lbs. dry weight. Add for fluids and wheel weights.
Loader ??? maybe 1200-1800 lbs.
You will be hauling around 10,000+ lbs. plus weight of trailer. Good luck and be careful.
RickB.
10-31-2000 14:22:48
Your plan would probably result in negative tongue weight on the trailer's hitch. These two items will require nearly 28' of trailer, although this is a (barely) educated guess.
