H Countershaft Nut
Bob R
11-01-2000 13:19:09
Whew !!!
What direction to loosen this nut . Its the belly pump type . Or is there some device to get at this nut . Been pounding on it with a long bolt and hammer both ways and nothing yet . Its been on there 48 years . Help please ...
I dont want to get the torches out . Hardened steel i'm sure .
the tractor vet
11-01-2000 19:35:04
 Re: H Countershaft Nut in reply to Bob R, 11-01-2000 13:19:09
Okay guys i am going to let you in on a littel trade secert, take big nut about 3/4 to 1 inch weld a piece of key stock that fits the slot ,put your home made tool in the slot take impact wernch remove nut.
Bob R Got it
11-01-2000 14:34:52
I got it with a longer bolt and had the head of the bolt at the outside edge of the nut . Just inside the groove . Hit my hand a couple dozen times , just glances off .
Thanks for the other suggestions , they sound less pain full . I came up with another idea , that I was thinking of trying .
Which is to take a bolt that fits lengthwise in the groove of the nut , weld a bolt on that like a "T" then use an impact wrench . Maby next time Later guy's
Oh , I need another seal it was another one of those double seal jobs again ...
I did the belly pump already , was tricky getting the shift arm back .
The Red
11-01-2000 14:44:40
 Re: Re: H Countershaft Nut in reply to Bob R Got it, 11-01-2000 14:34:52
Been there, done that and I am sure I will do it again. I am glad those old Hs don't understand cuss words.....
Jim
11-01-2000 13:32:28
I use a tire iron to take them off. The nut is normal right hand thread. Some times I lock the transmission in two gears to get it loose.
The Red Again
11-01-2000 13:31:39
Bob you might have to stick a big ol pipe wrench on there to get it loose. It will mark up the outer edge on the nut or dog as it is called, but you can smooth it out on a grind stone. Nobody will see it anyway.
The Red
11-01-2000 13:27:36
Bob both on the transmission and on the belly pump, you unscrew the nut counterclockwise. They can be stubborn!!!!!
Farmall Paul
11-01-2000 14:35:46
 Re: Re: H Countershaft Nut in reply to The Red, 11-01-2000 13:27:36
Bob- I just did one. I tried the tire iron, the pipe wrench. Nothing. Finally got a big BRASS punch from the tool man. About four hard smacks with the 3# and it finally came loose. You don't have to worry about damaging the slot if you use brass. Paul+
