340 Utility Restoration Help
Big M
11-02-2000 08:58:31
Does anyone know if the two side skirts underneath
the hood looked like? I am not sure if they were
just flat stock to match the front or if they were
made to match the back. I have the owners manual, but I can not get a clear picture of it.
Thanks, Big M
T_Bone
11-02-2000 10:44:18
 Re: 340 Utility Restoration Help in reply to Big M, 11-02-2000 08:58:31
Hi Big M, They were a flat piece with ribs like the curved pieces going to the dash. I've seena good picture but can't find it right now and will post it for you when I find it.
You can have them made at any larger sheet metal shop as they usually have a machine that makes loovers and the rib design is them same but without going all the way thru the SM making it a loover. Take a piece into them so the can copy the rib design and spacing, they also have a offset machine that makes them fit to the adjoining pieces really well.
T_Bone
T_Bone
Big M
11-02-2000 13:52:00
 Re: Re: 340 Utility Restoration Help in reply to T_Bone, 11-02-2000 10:44:18
Thanks, I'll look forwarded to seening the picture
that you send.
Big M
T_Bone
11-03-2000 23:23:30
 Re: Re: Re: 340 Utility Restoration Help in reply to Big M, 11-02-2000 13:52:00
Hi BigM, I looked and I have nothing thats shows enough detail on those side pieces. I thought I did. Mine doesn't have them on there either. I know I've seen pictures that show the detail tho as I was going to make a set for mine and they do follow the rib patteren of the piece to the dash. Let me know if you find out anything different.
T_Bone
