Farmall Super A
Bill
11-03-2000 07:23:11
What is the HP for a super A? Are they powerfull enough for planting 5 acre food plots in rough soil. Thanks.
gene b
11-03-2000 19:14:47
 Re: Farmall Super A in reply to Bill , 11-03-2000 07:23:11
this is why they built it over 50 yrs ago go for it
Dave in Mo
11-03-2000 10:04:37
The Model 'A' is plenty for 5 acres. You'll need a single bottom plow that fits the Farmall and a disc. You should be able to plow about an 1/2 acre per hour taking it easy next spring when the soil is damp but not soaking.
Bama Binder
11-03-2000 08:25:35
According to the Nebraska tests they were right at 17 hp at the drawbar. We plant food plots from 1/2 acre up to 5 or so acres by just disking the soil and then broadcast fertilizing and planting of clover and wheat.
As to whether the Super A is up to the task, I think so, given enough time. In the days when they were used by farmers, I think they were marketed to people with 80-100 acres.
When we go into virgin soil with a fair amount of vegitation, it can take hours of disking (we could probably go quicker if we plowed it first). We used a different color tractor with 3 pt hitch for the disk and spreader. If you go the Super A route, you may want to add a 3 pt hitch for the spreader.
If you go with more than a few food plots though, you may want a bigger tractor to cover more ground or keep the plots disked year aroung if the land isn't unde CRP...BB
