Converting a M to 12 VOLT system NEED wire diagram!!
Brian
11-04-2000 19:40:57
HELP!! I had a response to my question, which I really appreciated, however...my 1941 M is set up diffently than the schematics that I was given. I need to know what wire gives me the Voltage that charges the battery from the Instrument panel? (which is the light switch and the amp meter panel) This tractor was allready converted when I bought it, and I beleive that there was never any voltage going to the battery to keep the battery charged! I have not had problems with this, up until a week ago, when it just died when I was driving it. I have traced the wires and I can NOT find a wire that goes from the generator to the positive side of the battery for charging...I would really appreciate any feedback and help.
T_Bone
11-04-2000 21:34:09
 Re: Converting a M to 12 VOLT system NEED wire diagram!! in reply to Brian, 11-04-2000 19:40:57
Hi Brian, The easy way to solve your problem is to draw a small schematic of your existing tractor wiring and post it here. Then we can quickly tell you where it's wrong or correct.
Or search the archives as this has discussed at great length with excellant quality schematics from BobM. If it's wired according to BobM schematics then it will work!!! If all the parts are good!
T_Bone
