H QUESTIONS
Ben
11-16-2000 14:34:42
Could someone please tell me what the jets should be set at on an H. And also, procedure for adjusting valves, i know it says .018 hot,can i set them cold so they are in the ballpark. Fresh rebuild and I am not getting any fuel to cylinders, up to carb, not to cylinders??? Any help on this one would be appreciated.
ltf in nc
11-16-2000 15:06:15
 Re: H QUESTIONS in reply to Ben, 11-16-2000 14:34:42
Take the plug from the bottom of the carb fuel bowl and verify that you have a continuous supply of fuel. The float could be stuck.
The Red
11-16-2000 14:52:57
Ben I would suggest .020 for cold since you have a fresh engine. Those valves will be seating over the next 20 hours or so. I recommend you re-torque the head bolts after the second hour or so. Since you will have the rocker arm assembly off, that is when I reset the clearances to .018.
Open up the bottom jet about 3 full turns and see if that gets you going.
keith
11-17-2000 20:31:38
 Re: Re: H QUESTIONS in reply to The Red, 11-16-2000 14:52:57
thanks for the help on my H. had a problem with the H staying running and you suggested to try cleaning the gas lines and valves and I found a small stone in the shut off valve and fixed it . now the old girl runs like new . thanks again forever grateful Keith
