4 postion switch
Bergen
11-18-2000 16:30:11
The resistance coil on the switch, I suspect, is broken. Would this keep the charge permanently low or high? Can I make a new resistance coil?
gene b
11-18-2000 19:31:38
 Re: 4 postion switch in reply to Bergen, 11-18-2000 16:30:11
the res for the lites is for the rear one only the flat one goes to the field for high charge look at your decal if you have the right one it will be self explained but the front lites did NOT dim also the control box is where the system gets the gnd to work right we are talking about 6v A B and C tractors arent we
Jim Becker
11-18-2000 18:04:07
There are 2 resistors on the light switch.
One (field resistance) regulates charge rate. This is the flat one. If it is broken, high charge will work normally and low charge will be zero.
The other (dimmer resistance) is for the dim headlights. This one is round. If it is broken, you will have normal brights and no dims.
If I needed to replace either one, I would go to Radio Shack and buy an appropriate wire wound resistor.
Bergen
11-18-2000 20:58:06
 Re: Re: 4 postion switch in reply to Jim Becker, 11-18-2000 18:04:07
Guys, I'm sorry for not being clear, the switch is on an H and the field resistance is what we're talking about. Is there any way that the high charge setting would not wotk? The high and low setting on the switch do not make a difference in the charge rate.
Jim Becker
11-19-2000 05:42:03
 Re: Re: Re: 4 postion switch in reply to Bergen, 11-18-2000 20:58:06
And what is the unchanging charge rate? If it is zero, you may have a bad switch, a bad wire, bad connection on the wire or a bad ground. The ground has to be from the switch to the switch box cover, to the switch box, to the steering support to the tractor chassis. If any of them are bad, it won't charge.
Try putting a jumper wire directly from the generator F terminal to a good ground on the generator itself to test bypassing all these failure points.
Bergen
11-19-2000 06:16:10
 Re: Re: Re: Re: 4 postion switch in reply to Jim Becker, 11-19-2000 05:42:03
The unchanging charge rate is 5 to 7 amps with the tractor wide open. I'll do all these great suggestions tomorrow. The previous owner didn't shed the tractor much so it's quite rusty. Hopefully the ground is all that's wrong. Thanks guys.
Bob M
11-19-2000 05:41:27
Bergen - If the field resistor is broken, you'll get high charge on the "H" position and no charge on "L". Now if you're getting the same charge rate with the switch in either position, here's several possibilties:
1 - A bad light switch
2 - Wiring between the switch and gen is incorrect
3 - The original cutout relay was replaced with a voltage regulator. The "L" and "H" switch settings now have no significance - other than being two "off" positions for the lights.
Most likely the cause is #2 or #3....
Jim Becker
11-18-2000 18:07:25
Forgot to mention: field resistance 2.8 ohms, dimmer resistance 5 ohms.
charles
11-18-2000 17:11:50
Yes you can make a resitor coil. The best wire to use would be a mig welding wire, wrap around a piece of 1/2 round stock to make the coil .fasten the coil to the switch assy.THIS IS ONLY A QUICK FIX THE WIRE WILL NOT LAST VERY LONG, I WOULD USE THE LIGHTS ON THE BRIGHT SETTING TO TRY TO SAVE THE HOME MADE COIL. CHARLES
