Farmall 560 Power Steering
Brent
11-20-2000 10:26:21
I just hauled a Farmall 560 home (350 miles) from my uncles farm. I had to add 8 gallons of HyTran after I fixed the leaking hoses on the loader. Would running low on fluid affect the power steering pump? Does it need to be bled or is it just damaged? It doesn't seem to want to "help" steer at all.
Sam
11-21-2000 12:05:47
 Re: Farmall 560 Power Steering in reply to Brent, 11-20-2000 10:26:21
The manual stays to just turn the wheel all the way in each direction to bleed it. I did a bunch of work on the steering on my Farmall 560, and had no trouble bleeding - it seemed to work immediately.
I'm not sure how to best test it, but eliminating the question of hydraulic fluid supply as suggested by Les seems like a good start. There are 2 lines that come off the left side of the control valve (left as if you are driving). One line goes into the top of the upper bolster in front of the radiator, and one behind the radiator. Unless I'm all turned around, the one to the front gives the power for a left turn and works as a return line on a right turn. Opposite for the other line.
Anyway, loosen the front one and turn left and watch for fluid (with the tractor running). I've never done that, and don't know how much to expect - it might be a bunch. Might be a 2 person outside job. You can get to this line either at the valve or by removing the front grill.
I had access to one of the manuals, but was pretty confused until I got it apart because the manual covered the 460, 560, and a newer model, and there are different directions for manual versus power steering and for Farmall vs International. Once I got it apart I could match the instructions to the part, but was pretty confused for a while!
Good luck and give a yell if this doesn't make sense.
Les Repair
11-20-2000 17:21:10
Normally they self bleed. You might remove the pressure from the side of the pump housing and see if oil comes out when you start the tractor.
