Lifting a 560D motor
Alvin
11-20-2000 18:38:25
I am about to remove the motor from the 560. Where are the lifting points? I see at the rear of the head there a a couple of tap holes. Do you use the bolt holes for the thermostat housing at the front? I don't really want it to fall.Thanks Alvin
the tractor vet
11-20-2000 19:32:42
 Re: lifting a 560D motor in reply to Alvin, 11-20-2000 18:38:25
I prefer to use the left frount and the right rear head bolts , ihave a chain that i have made up for this perpose with two pieces of heavey 2x2 angel iron with the chain welded to the angle iron with a 5/8" hole drilled in it the chain is 1/4 high tinsel , it can handel 466 cu. in. engines with no problem. it is 48" long.
