Throttle On H Slips to Idle
Bob R
11-21-2000 07:13:51
Maby an adjustment . But seems to be a lot of pressure dowm to idle and away from the teeth . A pain indeed . Ideas on this ???
Thanks
Tom W
11-21-2000 13:20:43
 Re: Throttle On H Slips to Idle in reply to Bob R, 11-21-2000 07:13:51
Bob, I had the same problem. The tooth that is on the handle was bolted on. I unscrewed it and went to the IH dealer and bought a new one. Cost about $5 but it stays in one place now
Pete in PA
11-21-2000 09:50:45
Hey...
I had that same problem on my "H" - I had the saw
tooth style throttle, and my throttle lever had
become so worn that the flat metal part that
engaged with the sawteeth was worn completely
through. I temporarily fixed the problem with a
thin piece of sheet metal wrapped around the
throttle lever and sticking up into the sawteeth,
then took it apart and dropped a bead of weld on
the worn down area to build it up, filed it to a
point repainted and reinstalled...
works like a champ and looks like new
Pete
Rich Cota
11-21-2000 07:36:12
Bob, sounds like your throttle control handle or teeth are worn badly. Which kind do you have? The jagged saw tooth or the square teeth? Sometimes it is the rear end of the lever that slides on the cover plate that is worn so badly that it no longer exerts enough pressure upwards to hold the handle in the proper tooth.
Bob R
11-21-2000 12:45:04
 Re: Re: Throttle On H Slips to Idle in reply to Rich Cota, 11-21-2000 07:36:12
Its round with square teeth . I will take a peek at the metal part that slides . Does seem to be quite a bit of pressure the wrong way against it though .
About how much force is normal ? This is my first old tractor , so nothing to go by .
Maby take a look at my neighbors too .
There are a few of these around this area still . Alburg , Vt Sounds like you got what it is . Thanks
Rich Cota
11-22-2000 04:45:19
 Re: Re: Re: Throttle On H Slips to Idle in reply to Bob R, 11-21-2000 12:45:04
Bob, that single tooth on the lever is replaceable. If it is worn I would replace it.I bought my last one at my local Case-IH dealers.
The Red
11-21-2000 13:22:16
Bob check your spring underneath the cap to see if it is possibly broken. If it is OK, I usually add one more washer to give the spring more tension. That square tooth cap and throttle lever is an aftermarket which I have on one of my Hs.
Tom A.
11-23-2000 18:24:34
 Re: Re: Re: Re: Throttle On H Slips to Idle in reply to The Red, 11-21-2000 13:22:16
Bob:
I had same problem. Took a welding rod and welded on a dab to the tooth. Then filed it down to fit the notches. Probably need done again in few years, but it'll be somebody elses problem by that time I reckon.
Tom A.
