H Fluids Lubricants
Barry
11-21-2000 14:42:31
I have a '39 H. I need to know where to check the transmission fluid and hydraulic fluid, where the ports are for transmission and hydraulic fluid and what to use as transmission and hydraulic fluid.
The Red
11-21-2000 14:47:42
 Re: H Fluids Lubricants in reply to Barry, 11-21-2000 14:42:31
Barry the belly liftall pump takes 6 quarts of non-detergent SAE 30 or you can use today's IH Hy-Tran or Deere's Hygard. It takes 6 quarts for the belly pump by itself.
The transmission takes 6 GALLONS of 90W. The check hole is in front of the clutch pedal. If you pull that plug and 90W dribbles out, you are full.
