Order Farmall Cub Parts Online
Cub Transmission
Bernie Snarski
01-17-1999 21:38:38
I have a 47 Cub which jumps out of gear when in reverse. Any suggestions would be appreciated.
Utah Lynn
01-19-1999 11:10:33
 Re: Cub Transmission in reply to Bernie Snarski, 01-17-1999 21:38:38
Had the same problem in 3rd gear. A simple adjustment and tightening of a bolt under the cover solved it.
Walter Plouhar
01-18-1999 05:57:03
Bernie
Pull the top cover off of the transmission and check the forks that slide the gears, my bet is you will find one broken.
Had the same problem with my '65 cub with third gear.
