B and super C
BOB
11-25-2000 17:37:16
On one of the B farmalls I recently acquired,it has a cast iron gear shift nob on it.The nob has the old IH logo cast in the center,as well as the numbers 9637,was that a factory item for the B? The super C has a badly stuck engine.Would a C-135 engine out of a 275 swather fit without altering it,or should I fix up something older?
ih_bug
11-25-2000 22:15:28
 Re: B and super C in reply to BOB, 11-25-2000 17:37:16
the 135 engine will work but will have a dipstick for the oil and will be missing a bolt hole and a round piece of cast on the right side where the starter goes on the swather (it goes in opposite from the tractor) it will also up your hp especially if you go to a 154
Jim Becker
11-25-2000 20:28:49
The cast iron shift knobs were used for a while during the worst of the WWII rubber shortage.
RANDY
11-25-2000 20:37:56
 Re: Re: B and super C in reply to Jim Becker, 11-25-2000 20:28:49
ANY ENGINE FROM C113 THRU C154 WILL FIT IN A C OR SUPER C.
BOB
11-26-2000 10:56:38
 Re: Re: Re: B and super C in reply to RANDY, 11-25-2000 20:37:56
Thank you for your comments. I have installed C-113 engines in As before, and found the same starter difference.I was more concerned with the different water pumps and fan location.
