Can I get a new Steering U-Joint for my B?
1PWRFULH
11-27-2000 09:55:52
Do you think that Case could get me a new Steering Universal Joint for my B? The dang thing has too much slop to it! Thanks in advance!!!
RC
gene b
11-28-2000 03:26:32
 Re: Can I get a new Steering U-Joint for my B? in reply to 1PWRFULH, 11-27-2000 09:55:52
first make sure it will take grease then clean it up good put a clamp on one of the joints to pull it tight at the cross then heat it with a torch let cool do the same thing to other side will remave the play and go for it no one will ever know works for me great
1PWRFULH
11-27-2000 13:25:48
Ok thanks guys. I think I will give my local Case dealer a call and see what they say. Gosh dang!!! 120 bucks....hott diggity dogg!! Oh well....
RC
Brian
11-27-2000 12:26:26
Measure the shaft on both sides of the u-joint, the try going to:>Link
and>Link then do a search for "universal joint" I just checked at this web site so I know it works and it does. It may be that you will have to have a u-joint bored out to fit your shafts if one is not availble with a pre-finished bore in your shaft size. If one is not availble email me and we can talk about boring out a joint for you, I am a machinist and do odd jobs on the side.
Good luck, ~Brian
big fred
11-27-2000 10:59:29
I think you can get it, but you won't like the price, about $120 if I remember correctly. I'm just living with the slop on mine for now.
F14
11-27-2000 11:45:51
 Re: Re: Can I get a new Steering U-Joint for my B? in reply to big fred, 11-27-2000 10:59:29
Not familiar with that particular joint, but if it's just a generic universal joint, I ordered one from an industrial catalog for my F14, about $40. You need to know the shaft size.
