Year?
Alan Buckley
11-27-2000 16:10:11
A friend of mine has a Farmall H, he is unsure if it is a 1942 or a 1948. The serial number tag is gone. Is there any other way of telling the year?
If anybody knows can you please get back to me
also258@home.com
dick
11-27-2000 18:27:50
 Re: Year? in reply to Alan Buckley, 11-27-2000 16:10:11
Most of the major pieces have casting codes. An example would be 3-28-H, where the H is the code for 1938 (according to a post in the archives - I don't have Guy's book with me at the moment, so I'm not 100% sure this is correct, but it's close). For 1942, the code should be L or M or thereabouts; for 1948 somewhere around T, maybe (some letters were skipped in the sequence because they looked too much like others).
Anyway, the above should give you enough info to distinguish between a 1942 and a 1948 tractor. If you want to narrow it down further, post a casting code and someone will look it up for you I'm sure.
Jim Becker
11-27-2000 21:11:07
 Re: Re: Year? in reply to dick, 11-27-2000 18:27:50
A='31 and there were no letters skipped until '52. If it has the original engine (confirm with casting date codes) you can check the engine number. Not true of all models, but I believe the H engine and serial numbers were equal.
Andrew Helm
11-27-2000 18:08:24
one thing that i know of and i am not real shure about but i think that before 1943 International
still used the old IHC emblem cast in to all there parts i think after 1943 International just used the IH emblim cast in there parts
