No thermostat found
BTD
11-30-2000 14:59:14
I was removing the radiator on my M last weekend and took of the fitting that directs water into the top of the radiator. There was no thermostat where there should have been one. Is this the reason the tractor never got warm this summer? The gauge would read a bit above dead cold after a while but never higher. I will test the gauge with some hot water as soon as I figure out how to disconnect it from the block. Thanks in advance for the input!
BTD
Andrew Helm
11-30-2000 16:42:46
 Re: No thermostat found in reply to BTD, 11-30-2000 14:59:14
yes there should be it should be in that big bubble like thing that is connected to the water pump at least that is where it is on an H
haas
11-30-2000 16:28:35
Without the thermostat and with a good clean system, the tractor will likely hardly get warm unless you are really working it hard.
BTD
11-30-2000 16:39:47
 Re: Re: No thermostat found in reply to haas, 11-30-2000 16:28:35
I'm glad to hear that! The coolant looked pretty good when I drained it. I was hoping it was something basic like that. Thanks.
BTD
Bob M
11-30-2000 18:01:45
 Re: Re: Re: No thermostat found in reply to BTD, 11-30-2000 16:39:47
BTD - An Autozone #800-180 thermostat fits and works perfectly. Best of all the price is $2.99 - instead $20+ for a t'stat from the C-IH dealer
