Firing order
Bill Jolley
12-01-2000 17:06:45
I have a 1947 Farmall Cub that I just rebuilt. What is the firing order? And is this order on the cylenders or the distributer?
Bill
Bus Driver
12-01-2000 19:08:46
 Re: Firing order in reply to Bill Jolley, 12-01-2000 17:06:45
The firing order on a cub is 1-3-4-2. Cylinder 1 is at the front and cylinder 4 is at the back, etc. Every inline four with which I am familiar has this firing order- there may be an exception somewhere. This is the order on the distributor or magneto cap. No. 1 is marked on the cap. Turn with hand crank and observe the rotation direction of the rotor to determine the position of #3,etc.
ltf in nc
12-01-2000 20:20:32
 Re: Re: Firing order in reply to Bus Driver, 12-01-2000 19:08:46
Hey Bus Driver, haven't heard from you for a while. Hope all is OK. The exception for the firing order is 1243 but I do not recall the brand. 1342 is all this board needs to remember
Bus Driver
12-02-2000 06:15:50
 Re: Re: Re: Firing order in reply to ltf in nc, 12-01-2000 20:20:32
Thank you, ltf in nc for your kind words. Maybe I chose the name someone else was using. I discovered this site only two weeks ago. There is some really good stuff here and I feel a deep responsibility to be correct in any information that I offer. I don't want to cause injury to someone or damage to their machine. Please keep posting your good ideas.
Bill Jolley
12-02-2000 07:16:41
 Re: Re: Re: Re: Firing order in reply to Bus Driver, 12-02-2000 06:15:50
I would like to think every one that responded with info. So the 1-3-4-2 firing order is pertaning to the distributer and not the cylenders?
Bill
Bob R
12-02-2000 08:02:58
 Re: Re: Re: Re: Re: Firing order in reply to Bill Jolley, 12-02-2000 07:16:41
Yes , The cylinders are from front to back .1, 2 , 3 and 4 .
So you hook up your plug wires from the distributor . From number 1 on the distributor to the one cylinder plug on the engine .
I think the rotation is counter clockwise , you can determine this by yourself by rotating the engine normal operating rotation and watching the distribtor rotation .
Place the next plug in the fireing order sequence . Any questions , post again
Bill Jolley
12-02-2000 08:16:25
 Re: Re: Re: Re: Re: Re: Firing order in reply to Bob R, 12-02-2000 08:02:58
Thank you Bob! That is the information I needed.
Bill
Bob R
12-02-2000 18:04:40
 Re: Re: Re: Re: Re: Re: Re: Firing order in reply to Bill Jolley, 12-02-2000 08:16:25
Let us know how you make out . I figured you were really new to this , and gave you the very basic .
We can help with more , like timeing you can do too .
Hollar if you need a hand !!
Good luck
Lenny Fields
07-17-2002 21:03:08
 Re: Re: Re: Re: Re: Re: Re: Re: Firing order in reply to Bob R, 12-02-2000 18:04:40
Will some one please help me on the timeing order
on a 1952 oliver o-c-3 crawler.Magneto clockwise
order and head from front to back. looking at mag
from cap end i was told it could be-1-2-4-3- this doesn't seem to work .I was also told it might be
looking at cap sight glass was 1-3-4-2-. Please any help will be much appreciated
Bill {Antique Acres}
12-01-2000 21:37:15
Allis-Chalmers fires 1-2-4-3. First time I worked on my WD I wired it 1-3-4-2 like my good ol' Farmall's. Needless to say it didn't run right. It still puzzles me how two cyclinders next to each other fire in order. Well maybe not how they fire, but why they fire 2 in a row like that. Oh well. Bill {Antique Acres}
Dave Sholtis
12-01-2000 19:01:10
The firing order is on the same side of the block as the manifold it is stamped right above the hydraulic pump on the lower side of the valve inspection plate should be 1-3-4-2
Dave
