Farmall 350 Compression
Bess Brooks
12-04-2000 04:53:06
Hubby needs help. Can someone tell him how much compression his Farmall 350 should have?
dick
12-04-2000 07:26:57
 Re: Farmall 350 Compression in reply to Bess Brooks, 12-04-2000 04:53:06
My 300U has about 135# (C-169 engine) - I'd image your 350 (C-175 engine) should be in the same ballpark. Maybe someone else can confirm this.
T_Bone
12-04-2000 15:06:56
 Re: Re: Farmall 350 Compression in reply to dick, 12-04-2000 07:26:57
Hi All, Anything over 100 is considered great but more important is all cylinders are within 10% of each other. Another words 110, 100, 105, etc. as that means the engines has balance between the cylinders. If you had one at 80 then that is a bad cylinder when the rest are 100 plus, so the rings or vavles are bad on that 80psi cylinder.
Compression tests should always be done on a warm engine.
T_Bone
