3.0 hitch problem on international 686
Ashley Johnson
12-04-2000 16:54:08
When the 3 point hitch is up with a load. It jumps every 30 seconds. What could be the problem?
Ace S
12-04-2000 20:44:15
 Re: 3.0 hitch problem on international 686 in reply to Ashley Johnson, 12-04-2000 16:54:08
Let set over night with it up and some weight on it if it goes down over night you know you have a leak, if not you need some adjustment
Les Repair
12-04-2000 17:14:43
The hitch is probably settling down and the valve is correcting. The O ring in the lift cylinder could be leaking.
Mudcat49
12-04-2000 19:22:26
 Re: Re: 3.0 hitch problem on international 686 in reply to Les Repair, 12-04-2000 17:14:43
Had the same problem on my 686 ( same as 656 in hitch dept.) new o rings fixed it up. But in some cases the inside of the cylinder can be wore or scratched too, I cleaned mine with a cylinder hone.
