Aftermarket P/S
Brandon
12-12-2000 10:52:25
I am curious t what an aftermarket power sterring setup would cost for a Super M. (Char-Lynn). Thanks.
gene b
12-13-2000 04:30:32
 Re: Aftermarket P/S in reply to Brandon , 12-12-2000 10:52:25
MATHIS has them for 500 used you want a seperate pump works muck better mounts under the hood as does the unit cant be seen just have to keep a good belt and tight THE behlen UNIT MOUNTS OUTSIDE THE HOOD LOOKS TERRIBLI WITH LINES AND SO go with the CHARLYNN and seperate pump wont be sorry
TJ
12-12-2000 19:00:04
you shouldn`t need the pump if your tractor already has live hyd. charlynn should have a flow valve that will feed your steering first that should help keep the price down and if you get a used one try to get the steering shafts with it so you dont have to cut your old ones they may come in handy some day
ED
12-12-2000 18:35:10
To Brandon Re: aftermarket p/s
What you need is called a torque generator made
by Char-lynn. You also need live hydraulic power. Ball park estimate would be $400 for torque generator and $500 for the hydraulic pump, plus hoses and fittings. p.s. you may need a flow control to keep flow constant.
Brandon
12-12-2000 11:26:23
 Re: Re: Aftermarket P/S in reply to Jon, 12-12-2000 10:58:39
Thanks to both of you that answered. Jon, where are you located? Thanks.
Jon
12-12-2000 12:57:22
 Re: Re: Re: Aftermarket P/S in reply to Brandon, 12-12-2000 11:26:23
N.E. KS
Jon BTW
12-12-2000 11:06:56
there is a char-lynn PS on the YT auction. Its on the first page of the Parts category.
