Farmall 400
alan bane
12-13-2000 15:13:54
What would a Farmall 400 be worth. The tires are about 40%, needs paint but all metal is good and straight and has power steering?
JohnIH
12-14-2000 10:33:29
 Re: Farmall 400 in reply to alan bane, 12-13-2000 15:13:54
Alan, I bought my 400 in 1999 in northern IL for $2300. It had the following spec.
1. Working TA
2. Live Hyd.
3. Aftermarket power steering.
4. Aftermarket 3 point hitch.
5. 12 volt converted.
6. About 60% rubber.
7. Narrow front.
8. New paint.
9. Tin about average to above.
I hope this helps.
John
dick
12-13-2000 15:53:51
Alan:
Worth depends on a lot of things besides those you've listed. First off, how well does it run, assuming that it does? Also, where are you located (values vary widely in various parts of the country). Does it have the following, and do they work: TA, Fast Hitch, hydraulic remotes, IPTO, lights, 12V conversion, tach & other guages?
I expect that if you supply most of the above information, you'll be able to get some reasonably good idea of worth from the people on this board.
Pete
12-13-2000 15:29:23
Al, not as much as it should be! dealership where I sell had 300 row crop traded in on new Kubota,
good metal, power steering, quick hitch, good rubber, loader, QH mower, 2btm QH plow, QH back blade, we painted it (good), rebuilt engine(top end), and rebuilt TA, sat there for 2 yrs, finally
bit the bullit and took $2300! I shoulda bought it I guess! Pete
