300 timing problem
Bryan Collett
12-16-2000 08:54:19
I have a 300 that esems to jump timing. I set the timming and it run. Maybe a min. or two back fires in the exh. and dies. Check the timming and it is 180deg. out rewire the cap aand it starts runs back fires and dies. Timming is now back to correct. Does anyone any ideas of where to look or what to do. thanks
LynMn
12-16-2000 17:04:51
 Re: 300 timing problem in reply to Bryan Collett, 12-16-2000 08:54:19
If you have a IHC dist.The gears in the dist. may have failed due to lack of lube and normal wear.You will have to remove & take apart dist. Heed the Reds advice on T.D.C.
The Red
12-16-2000 09:09:33
Bryan you will have to remove the distributor assembly including the base unit from the engine. There is a distributor drive key that probably is sheared where the distributor gear bolts on. I recommend you get the engine on #1 TDC before you remove the assembly and note or take picture of the rotor position.
Bryan Collett
12-17-2000 15:51:18
 Re: Re: 300 timing problem in reply to The Red, 12-16-2000 09:09:33
It was the dist. drive gaer pin. I'm up and ready from more snow. thanks!
The Red
12-18-2000 11:28:48
 Re: Re: Re: 300 timing problem in reply to Bryan Collett, 12-17-2000 15:51:18
Congrats! As Sergeant Preston would say to his dog, "King the case is closed." "RUFF!!"
