Cracked Block Farmall A
Al_Wa.
12-16-2000 19:40:20
I read thru the archives on "cracked blocks" and I'm in good company. My A has a pin hole in the lower right hand corner of the block where it has been brazed. At one time the corner of the block had completely broken off then was brazed. Whoever did it, did a pretty good job. Water is getting into the engine and also weeping thru a pinhole to the outside. (kinda foamy) I can't picture how the water jacket runs in that area of the block. If someone can help I would appreciate it. Thanks in advance.
Al
gene b
12-18-2000 03:37:15
 Re: Cracked Block Farmall A in reply to Al_Wa., 12-16-2000 19:40:20
are you talking about the steering side in that area how high up did the crack go might have an internal crack also the o-ring at the bottom of the sleeves also a cracked head try some of the new ceramic type of stuff you would have to rig up some sort of pump to circulate the mixture would be easy connect from the drain plug to the radiator this is some excellent stuff hear good reports about it
Al_Wa.
12-18-2000 18:27:07
 Re: Re: Cracked Block Farmall A in reply to gene b, 12-18-2000 03:37:15
Gene,
Thanks for the response.
"are you talking about the steering side in that area how high up did the crack go might have an internal crack also"
Yes the crack and the braze are on the front right corner. The corner of the block including the two block mounting holes were broken loose and brazed back to the block. The crack is visible from under the block at the oil pan mounting face. It does not extend up past the original braze.
"some of the new ceramic type of stuff you would have to rig up some sort of pump to circulate the mixture would be easy connect from the drain plug to the radiator this is some excellent stuff hear good reports about it"
I'm not sure what your talking about here, is these like the GUNK stop leak stuff you put in a radiator only better?
I know the right way to fix this is tear the whole thing down dig out the old braze, heat the block up and braze it all again. I'm getting lazy in my old age and trying to get off light.
Thanks for your thoughts.
