504 Verry hard to start
Billybob
12-17-2000 19:14:37
Have a 504 TA will barley start.Will Hardly
start at idle . Will run good after it warms up . Gave it a complete tune up (no change) . Help Bill KY
buckeye al
12-19-2000 16:10:30
 Re: 504 Verry hard to start in reply to Billybob, 12-17-2000 19:14:37
Check the ignition resistor bypass feature. Best way I've found is connect a clip lead from battery to battery side of the coil.
Later.
PS.... Don't run it this way. You'll cook your points and maybe the coil too.
Lazyhorse
12-17-2000 19:57:15
Check the timing, and the spark advance weights in the distributor.
JLE
12-18-2000 04:29:22
 Re: Re: 504 Verry hard to start in reply to Lazyhorse, 12-17-2000 19:57:15
Check for complete closing of choke, (asume it is a gas engine) this will make it hard to start.
