Balancing
Bryon
12-19-2000 11:25:19
I'm planning to rebuild my M engine and put in 4.30" pistons in it for pulling next spring. The last time I had it running at full throttle, it vibrated quite a bit, more than I remember it doing. Should I have the crank balanced? It'll be turning about 1500 or more rpm's. Will a part by part balancing be good enough or should I have the whole assembly done together?
scott
12-20-2000 13:19:37
 Re: Balancing in reply to Bryon, 12-19-2000 11:25:19
To do it right I would balance everything the crank, rods, pistons, front pulley and the flywheel.
