Order Farmall Cub Parts Online
1950 Cub Farmall won't run
Bill Jolley
12-21-2000 11:52:20
Thanks to all of you guys help I finialy got my Cub to start. The only thing now it will only run about one half of a minute. It has a new plugs,plugs wires,distuberter cap,roter,points,coil,and carberator kit. When I chock it it dies even faster.
Bill
Phil Auten (TX)
12-22-2000 19:21:25
 Re: 1950 Cub Farmall won't run in reply to Bill Jolley, 12-21-2000 11:52:20
Bill,
Disconnect the gas line at the carb and check for a good steady flow. If not, you will need to find the blockage and clean it out, including, possibly, the tank. My Cub had a bunch of crud in the tank and I was able to just flush it out and it works fine now. Also, add an inline filter between the sediment bowl and carb. It'll save you a bunch of work later on cleaning out the carb.
Also, make sure the vent hole in the gas cap isn't plugged. Had one of those too. :o)
My 2¢,
Phil
The Red
12-21-2000 11:58:20
Bill after it conks next time, pull the spark plugs (careful they will be warm) and see if they are soaked in gas.
