Winning noies from hydrulics
Bill Jolley
12-21-2000 12:01:02
My 1961 Cub has a wining noise coming from the hydraulics.It stops making this noices when you rase the hydraulics but starts making it again when they are all the way up.
Any ideals?
Bill
Justin
12-23-2000 16:45:02
 Re: Winning noies from hydrulics in reply to Bill Jolley, 12-21-2000 12:01:02
The HYD on my Cub wine to. That's because it's 10deg here. After the oil worms up the winning stops. Your problems might be different then just being cold.
Tom W.
12-21-2000 15:54:46
When the relief valve sticks like that, the Hyd. fluid will get hot and foam and your lift won't lift. I had that happen on mime and the lift unit got so hot you could not touch it. I had the lift unit rebuilt at the local IH dealer. It wasn;t cheap but it works like new now. The lift unit is easy to take off the tractor and that will save you some money if you have it rebuilt.
T_Bone
12-21-2000 12:17:32
Hi Bill, Sounds like your presssure relief valve is stuck shut. Probablly just needs to be cleaned.
T_Bone
